well this is the third time i've pulled the tranny out first time to switch it out 2nd to replace everything from engine to tranny. now this time for a slave cylinder. each time i've just unbolted the master cylinder and took the whole thing out. how can i disconnect the (quick) fitting from the slave cylinder it's a fm 146 tranny.
i looked and it looks like ones suppose to be there but i don't see one. i don't remember if there was one or not this tranny was installed in early 05'
cddavis9343 wrote:i looked and it looks like ones suppose to be there but i don't see one. i don't remember if there was one or not this tranny was installed in early 05'
I've heard of guys taking a margarine container and cutting a strip to fit, using that to disconnect it.
There is also a special tool you can get from Ford to remove it.
