Chop Top Project
Chop Top Project
Okay started my chop top project, this is what I have gotten done so far
first took the seats out and carpet, than all the plastic in the back of the truck. I disconected the rear window defrost and my rear window wiper and fluid pump, un hooked the rear cab light.
Than came the head liner and rear windows, This was a little ruff. I had no problem getting the first window out, it took some time but it came out all in one piece, than the other one blew out real easy, but I will not need these windows so if you want to clean the mess its a faster way of getting the window out, also if you cannot find some one to take the whole window, than you can put it in a bag and take it to the dump. I had made holes in the plastic to get to the bolts in the summer so it was easy to get at them. But if you dont have holes there than you will need to take all the side plastic off to get to them easy. IF you want to keep your headliner than make sure everything is taken off that is holding it down and pull it straight out from the rear of the truck, and do not bend it at all!!!
Rectum, damn near killed em
Okay well its off!!! haha it was fun, VERY fun, haha and well 100% easer than I ever thought it would be SO FAR. I used a sawzall, I got two new blades. It cut very easy, just make sure you get a blade that is long enuff to go all the way though. First I cut the rear pillars off, than closed the hatch to brace the top from moving around when I cut. Than I got inside the truck and cut along my line from the inside. You should have somthing for your ears here, if you are inside it is VERY loud! When I got the top off I got a friend to open the rear hatch while I was inside the truck and I lift up from inside while he lifted the hatch. Its not that heavy but that hatch is about 90% of the weight. well here it is.
Before
After
Before
After
Before
After
Before
After
okay so this worked out real nice so far, first time I have used a angel grinder. I cut the brace on the sides and than just beat it with a hammer untill it bent up than just grinded away and it is closed up. Now I am not going to just leave it like that but its a start. Here it is, and a pic of the truck out of the car port
I took all my old weather striping off from around the rear hatch and off the top that I cut off and put it around the truck where the window mounted, I also got it to fit around the top of the truck but not around the beams. I am going to go and try to find some new weather striping that I can use, I may try and make it so that the beams on the top are tapered down so that I can put the striping around the whole choped part of the truck. But not back where the rear beams are, I am going to try and fill it in and work this fiber glass way first.
here is where I took the striping from.
and put it here
and put it here
chop top
looks good man i just have one suggestion.in the past when i do the chop tops on these rigs i cut a little more off the top of the cab.i noticed you left a 2 inch lip on top. is there any special reason you didi that?i usually carry the window line accross the top.
Re: chop top
I just wanted to make sure I had somthing to work with, its almost flush with the wind edge. Dident want to be like ahhhhhhhh shit I cut too muchrockcrawlerbronco2 wrote:looks good man i just have one suggestion.in the past when i do the chop tops on these rigs i cut a little more off the top of the cab.i noticed you left a 2 inch lip on top. is there any special reason you didi that?i usually carry the window line accross the top.
I want to make a "soft top"greenmachine89 wrote:Lookin good. What are you going to do about closing the cab off? I have never found a setup that looks good so I never have attempted the chop top. Hope to see more pics!
So it will be more like a full size bronco rag top... Know what I mean?
soft top
Il try to take some close up pics of my soft top for you it really turned out nice and functional.dont forget dry!! lol
http://pg.photos.yahoo.com/ph/wblbronco ... /my_photosgreenmachine89 wrote:Lookin good. What are you going to do about closing the cab off? I have never found a setup that looks good so I never have attempted the chop top. Hope to see more pics!
Bill
1990 BII, 4.0, (sold)
2005 F150 SCrew
'84 Ranger under construction
2005 F150 SCrew
wow that is clean truck! what did you use for the rear? not the tale gate but behind the seats? is it off a ranger?04sd wrote:http://pg.photos.yahoo.com/ph/wblbronco ... /my_photosgreenmachine89 wrote:Lookin good. What are you going to do about closing the cab off? I have never found a setup that looks good so I never have attempted the chop top. Hope to see more pics!
The rear cab panel is made of wood, laminated hardwood strips to get the curve of the roofline, and then coated with black bedliner. Uses a ranger rear slider window. An aluminum u-channel along the botom channels water to either side when the bed cover is on. I really don't use it much in the winter but I just bought a snowplow for it for next year. The bed cover and cab panel can both be removed in less than five minutes. Not shown in the pictures is the rear seat rollbar and bikini top that goes on for most of the year. This is a summer time toy and now winter driveway plow, I have a new F150 S-Crew 4x4 for a daily driver.
Bill
2005 F150 SCrew
2005 F150 SCrew
