I researched the internet for remanufactured injectors.... really, there just cleaned in a machine specifically for that, and then new o-rings and end-cap put on 'em.
Anyway, several places do them for $15 each... ship to them, thay send back "done".
Question : it looks like removing them is pretty easy. ... (after taking off the air intake plenum). True?
Anyone ever have trouble lifting the fuelrail free from the injectors .... old/dried o-rings super-stuck in the fuelrail? Is the fuelrail brittle or flimsy .... easy to bend ? (I'm not fumble fingers idiot, but if it's brittle, it'd be nice to be forwarned).
how does it run? what are some of the problems its having? never know we might be able to help
Cranks long time to start. Much easier to start by cranking only a couple seconds, then stop and recrank again.... usually listening for fuel pump to "cycle". (90% of the time, fires right up). ( In severe cold it may fight to get running on second crank).
After cold start, it high ides, (1400-1500 rpm), for minute or so, then drops to 750 or so. (Normal. I think).
Infrequently, the high idle roams from 1000 to 1400. Rare though. And even rarer, after idling down to 750, it sometimes almost stalls, but always catches itself before it does and then resumes to hold a steady 750.
Even on warmer days though, it sometimes can be a bitch
after it been running and shut off and then minutes later it's tried to start. (I never smell gas....ever, so I think it's always an issue of leanness. Rough estimate, it gets about 11-14 mpg.
Very sluggish power... (don't know what a good running 2.9 feels like anyway), but most anything on the road can out accelerate it from a light.
Shop tested fuelpump pressure at test port on the fuelrail. (I thought it might be giving up). They said it pumped up to 38 psi at "key-on". Book calls for 30-40, and I know that is not a conclusive test. It might not be consistant .....
or the pressure regulator system might be acting up at times. (Don't know anything about it).
Plugs, cap, rotor, TFI, pick-up coil all new. (Wires looked good, could'nt see the need). Idle Air Control gizzmo is working good...took it off, cleaned and "book" tested it.
There's no stored error codes in the ECU....clean. (11 - 11 = no codes.)
What else can I tell ya? Oh yeah, I cleaned the engine to firewall ground strap connections...and added a
second one to boot. Then included one that also runs back to the battery negative. (If I knew where the ECU was, I'd run a ground right to it's mount too).
Last brain storm ...mayby the cat converter clogged? .... does have 185k miles. (prolly origional one).
If I bought a new one, two choices. A $50 new "universal" one or a $90 "like OEM" replacement? Should I avoid the cheapy? .... maybe poor flow performance? I dunno?
There ya go.... thats the whole deal.... biggest bitch...does'nt start right. Second bitch...super sluggish.
