Does this look right?
I am finally installing the radius arms on my d44 and the bushings dont look right. Its like they are too small and are being smashed into place. Is this right? It looks ghetto to me.
did you make sure they were flipped right?
they should say on there top and bottom
Ya I checked like 4 times before starting the bolts in. In the drivers side I did after the passenger side and I could not get why the bolts would not line up with the holes and noticed that I had the bushings flipped. That made me feel good that it messed up the lining up so much that it would fit, so I know I put them on right. Both sides did the same bulging so at least its consistant.
mine did do the same thing just not as bad...I wouldn't realy worry to much about it. as long as you got the right side up you should be fine.
good to see you working on the truck!
It feels good to work on it again. I really dont have time to work on it, but we made and offer on a bigger house and are going to move in Jan, so we have to clean up this house so we can put it on the market soon. My wife said that most other things can wait for the b2 to get moved. I wish I had time, I forget how satisfying it is to actually work on it.
UPDATE!!!!
I got a chance to work on the B2 with it was almost 40degrees out. WARM!! Also had to move some snow off the driveway, but I still had to use a heater. Anyway, the front axle is in place with the coils mounted. I havent mounted the steering, trackbar or radius, but still progress. Its much more fun then painting and fixing our house to sell.....
nice! definatly keep the progress comming!
