								84_4x4
		Posts:  229  		Joined:  Mon Sep 04, 2006 8:36 pm
						Post
								by 84_4x4   »  Tue Oct 24, 2006 8:02 pm
			ok i went out to start my bronco 2 the other day and it turned over but would not fire so i checked spark and i had spark on all 6 cylinders so i checked fuel and i had good fuel pressure to my carburator. but when i would turn it over no fire and occasionally a little backfire out the carn shooting gas all over the bottom of my hood. i couldent figure out my problem but was a simple fix do you know the answer if so reply see how smart you are when seams impossible
								mccutcheon4
		Posts:  153  		Joined:  Thu Mar 16, 2006 8:27 am
						Post
								by mccutcheon4   »  Tue Oct 24, 2006 9:12 pm
			Loose nut behind the wheel ?
								Bob Myers
		Posts:  274  		Joined:  Sat Apr 24, 2004 6:33 am
						Post
								by Bob Myers   »  Wed Oct 25, 2006 8:42 am
			SOunds like someone has been messin with the timing, either cam or dist, or both
92 XJ-wifes toy
								84_4x4
						Post
								by 84_4x4   »  Wed Oct 25, 2006 4:15 pm
			close but nothing was adjusted does have something to do with distributer
		Posts:  1545  		Joined:  Mon Apr 19, 2004 5:21 am
						Post
								by DBrown   »  Thu Oct 26, 2006 4:08 am
			what motor are you working on? I am quessing a 2.8?
what does the voltage look like going to the coil?
								Joel H
		Posts:  137  		Joined:  Mon Feb 13, 2006 11:08 am
						Post
								by Joel H   »  Thu Oct 26, 2006 9:59 am
			Sounds like your fireing order was all messed up. Out by one were you?
								84_4x4
						Post
								by 84_4x4   »  Thu Oct 26, 2006 11:58 am
			eh distributer cap was wet sending voltage to every piston at same time but some of yall were very close
