There is a run coming together for the weekend of the 5th. There are plans to run trails and go play on the moon rocks while camping out at halfway flats. If anyone can make it out even for a day it should be alot of fun. Here are the plans in detail.
http://broncoii.org/fordforum/index.php ... 9467&st=20
Naches WA Aug 4,5,6
no v8? why drive?
Naches WA Aug 4,5,6
87 4X4 Ranger 306ci AOD NP205 fw d44/8.8 5.13s
94 4x4 Navajo 8" lift
are you going to have your truck ready? how is the progress comming?
no v8? why drive?
Not the bronco, I havent touched it in a few weeks because I was on vacation and then I have been working on everyone elses projects since Ive been back so I havent had the time to work on my own. Its going to be a while yet until that thing moves, I still have to finish mounting the airshocks and get a permanent track bar made. Then I have to put the motor back together, wire it up and then rebuild the dana 44. Then it should be able to move, but I still have a ton of small things to do like beef up brackets and mount rear shocks and make a dashboard to mount the insturments. Ill be riding up with my roomate in my old '90 extended cab so we will just take turns driving and I just got off the phone with another friend of mine that has a '90 stx and hes up for it as well.
