onewontwo's '88 bronco ii
Posted: Fri Apr 04, 2008 2:59 pm
by onewontwo
Well I just finished up my rear suspension.
F-150 leaf springs and front hanger bracket. Picked the pair up at the junkyard for $100. It was a very straight forward and easy swap. I think it will level out once I get the 33's on the rear.
I just need to figure out what rear axle I'm going to use!
Stock Hanger
F-150 Hanger
Before Swap
After Swap
Posted: Sat Apr 05, 2008 3:22 pm
by Phillippi
Are you using stock B2 rear springs? Looks good.
Posted: Sat Apr 05, 2008 6:45 pm
by onewontwo
The leaf springs are off of a 2wd f-150 to keep them 2 1/2" like the stock b2 springs. I believe the 4wd is 3"
The shocks are for a b2 with 6 inches of lift.
I centered the front axle today, but didn't get any pics. It looks alot better.
Posted: Sun Apr 06, 2008 6:38 am
I was going to ask about that but I thought it just might be the angle of the pic and if the tires were turned a little...
looks good keep the pic's comming!
Re: onewontwo's '88 bronco ii
Posted: Mon Apr 07, 2008 1:03 pm
by Joel H
onewontwo wrote:Well I just finished up my rear suspension.
Ya the F150 stuff will get you 6" lift easy without blocks.
Posted: Sun Apr 13, 2008 3:25 pm
by dirtcowboy
Any particular year of F-150 stuff to use? How does a BII ride after the swap?
Posted: Wed May 21, 2008 1:37 pm
by onewontwo
I wasn't real particular on the year. As long as they are 2 1/2" wide you can use your stock shackle. By the way the F-150 leafs I picked up were a 4 pack w/ overload out of a 2-wheel drive truck. I believe the 4-wheel drive trucks are 3" springs.
Posted: Thu May 22, 2008 2:33 pm
by onewontwo
Well, it's not completely done, but both axles are underneath and this is how it is going to sit.
I'm really happy with how it looks.
Posted: Sun Aug 24, 2008 3:31 pm
by onewontwo
Posted: Thu Oct 09, 2008 8:19 pm
by onewontwo
Posted: Sat Oct 18, 2008 5:00 pm
by onewontwo
Well, I skipped the EB grille and just installed round headlights, which is all that I really wanted. Drilled 1 hole on each side and it bolted right up, including the plugs. $15 at the junkyard for the pair off of a Bronco Custom. Not sure of the year.
Along with the new headlights I also went ahead and installed "gauge faces." I find it hard to see those dim stock gauges while night wheeling. These gauge faces are very, very clear to see at night. I never really heard anything about them, they are not what I expected, but that is not a bad thing at all. The install was straight forward and extremely easy to do. It did not involve removing the instrutment cluster which is something I really didn't want to do.
Tach
Speedo
I've been working out the issues in my suspenion system since I've been driving it. I went for a ride today and actually checked to see how much travel I have. I'm maxing out my rear shocks easily and I plan on installing the mount below the frame or along the inside. Since I am maxing out my rear shocks I didn't get to experience the full flex of the wristed arm yet. I didn't get those pics that I promised yet, but I'll make sure I get them posted sometime soon. So here is a pic of what happens when you max out your shocks. My suspension is capable of so much more flex than this. I'll be moving the shocks within the week!
For some reason I never posted this pic when I was doing my body mounts but here is a more detailed pic of the custom sleeves and plates used in the body mount install.
Posted: Fri Jul 03, 2009 11:01 am
by MJONES602
hey gotta quick question what kinda coils did you use for the front i havnt decided yet i like your stance alot
Posted: Fri Jul 10, 2009 1:21 pm
by onewontwo
Guess I'm a little late on this post but they are 3.5" superflex eb coils from bronco graveyard. I'm trying to keep the cost done.
Posted: Wed Jul 22, 2009 4:33 pm
Almost thought that was my bronco.....
I did hydroboost on my Bronco II. It was really easy.
