O.B.A. ?'s
Post by FatMan » Fri Oct 21, 2005 2:19 pm
HOT DAMN!!!! it works great info thank's... the switch was exactly how i thought it was. i'll post up some pic's later today right now i gotta get to ACE to get some hose and a freeflow chuck.
i've heard that the freon act's as a lubricant for the pump in auto a/c unit's i dont know if it's true but i know this much the pump wont see near as much action as it did while working as a a/c unit. i will start with a cap full and see from there...
Post by DBrown » Fri Oct 21, 2005 6:05 pm
I used a tool oiler and it worked good. just put a oil seperator on the outlet line before the tank.
Post by FatMan » Fri Oct 21, 2005 6:56 pm
DBrown wrote:I used a tool oiler and it worked good. just put a oil seperator on the outlet line before the tank.
will do...
here are some pic's of what i have.
original bypass switch with center spring and screw removed.
switch installed.
back of switch oposite side of switch cut off and sealed with rtv to keep moisture out.
air hose male connector.
Post by FatMan » Fri Oct 21, 2005 6:58 pm
that was pretty damn easy thank's all.
Post by Nobody » Fri Oct 21, 2005 8:48 pm
Did you try it out yet? :cool:
Post by FatMan » Sat Oct 22, 2005 12:30 am
got it oiled tonight and showed the wife she was almost excited as i was.
Nobody wrote:Did you try it out yet?
not yet im going to pick up some hose and air chuck on sunday or monday. it does blow air thow i think i have a gauge lay'n around somewhere if i find it im going to run it so i can see what kind of pressure the pump is putting out.
Post by ranger5.0 » Sat Oct 22, 2005 7:34 am
FatMan wrote:got it oiled tonight and showed the wife she was almost excited as i was.
She still made you put the tool away though, huh. :D
B2JAY
Congrats
Post by B2JAY » Sun Oct 23, 2005 12:55 pm
Lookin good!
Post by FatMan » Sun Oct 23, 2005 8:32 pm
ranger5.0 wrote:She still made you put the tool away though, huh.
unfortunetly :redneck:
B2JAY wrote:Lookin good!
thank's i have a bunch of stuff planned for it as long as i can keep at least 3 wheels on the ground.. LOL..
