1. just so im straight- with a stock a/c compressor 1st i need fittings that will go from the compressor to a "T". from the "T" i need (2) female quick diconnects were i can route hoses how i choose.
my plan from there is to route (2) seperate hoses (1) to the front and (1) to rear both with female quick disconnects. i will have a length of hose that i carry with (1) side male connector and other with air fitting so i can go from front of rig to back of rig to fill tires/ect.
2. i want to filter my a/c compressor so will any intake filter work? i know kilby makes filters for YORK'S but can i use what there using for a stock unit?
3. will the engine oil hurt the compressor? i know they make compressor oil. how much to add and where to add?
4. if i decide to add a Coalescing Filter for filtering the air will that catch all the oil i put in to lube the a/c compresssor? will it mess up the Coalescing Filter or is that its job?
5. at this point with out tank will i need a pressure switch. im thinking i wont cuz theres no tank to regulate pressure.
6. if im not using the idle to move more air do i need the DPDT relay?
7. a/c low pressure cut out switch i know i have to bypass it but can i just cut it out and leave it open or does pwr still have to be routed through the wires?
8. what is a free flowing chuck?
sorry about all the questions at once but i really want to understand this right the first time and get it going.
