86 BII 4wd Eddie Bauer Automatic Trans Slip?
Posted: Wed Dec 18, 2013 7:43 am
ok so im pretty that my automatic 86 Eddie Bauer B2 has the A4DL tranny although im not sure, did all the EB B2's all come with that tranny?
anyway...so when its cold reverse does not like to engage, it takes some cycling through all the gears and some patience for it to engage with a clunk but once it does its smooth sailing backwards. the drive gear engages fine every time, with a bit of a clunk but i doubt it anything more than a tranny mount replacement wont fix; what worries me is the slipping between gears. when i got the truck it had sat for about a year and the owner told me that the last "maintenance" he had performed was a tranny fluid change but he was unsure if he used the proper fluid so i drove it drove it home and after spending 2 hours to drive 5 miles due to bad electrical problems that kept shutting of power to the ignition and fuel systems. in the spurts of driving time on the home i did notice that it would rev awkwardly high between 2nd and 3rd gear and didnt notice any overdrive. i did a tranny fluid and filter change twice to rid it of the questionable fluid and while it did run a bit smoother, longer distances showed more slipping: off the line it takes off smooth and with a steady acceleration will cycle through all 4 gears and will continue to run smooth thru 92mph for a couple miles (didnt want to get a ticket so i slowed down) upon releasing the gas pedal it slowed as expected but when it came time to accelerate again before coming to a complete stop (about 25-30mph) it over revved as if on neutral and had to come to a full stop before it would engage again, and then as if nothing happened it was fine thru all gears so i decelerated and it did it again. it happens from what i can tell between 2nd and 3rd gears or about 25-30mph. i checked the vacuum line and replaced it was it was the original from factory as well as the modulator, tested again and now it will re-engage while moving after deceleration with some finess and feathering of the gas pedal but it will clunk as if getting kicked in the ass by a mule! any suggestions?? also, the shifting on these trannies, is it vacuum actuated hydraulics through all ranges or is there an electric shifting component that im missing??
