rear axle seals
Hunter66
rear axle seals
Post by Hunter66 »
everything is off around the axle but the axle wont budge. any suggestions of how I might get the axle out w/o doing damage;. I have Detroit lockers in the rear if that helps. she is a 70' bronco,
Re: rear axle seals
clem
Re: rear axle seals
Post by clem »
A '70 bronco has a 9" rear end, no c-clips.( dave you know that :rolleyes2: ) Use a slide hammer after you remove the four bolts behide the drum. I used a piece of threaded rod (allthread?) with a large washer and nut through the hole on the axle, and a picce of smal pipe with two railroad spikes welded on it. see crude picture. I hope this helps, Oh you'll need ice for your hand after, I suggust cold beer.
slide hammer 2.JPG (16 KiB) Viewed 2678 times
'73 vw bug
'70 vw camper van
'98 jeep tj
2010 ranger
'56 international s110
Re: rear axle seals
sorry, my bad
drofman
Re: rear axle seals
Post by drofman »
I have just wrapped a chain around the axle and used it like a slide hammer
