Which C4??
Which C4??
Im planning on putting a 5L into my bronco mid-august. Im running a C5 right now, from what I understand I can just swap over a bellhousing/TC from a C4 trans to get it to match up. What im not sure is what year C4 to get it from, if it matters? Also I would like to eventually use a Dana 20 twin stick t-case. To get this to match the C4 I need a C4 tailshaft from an early bronco...is that correct? Or do I have to buy an adapter for like 500$? Any info is greatly apreciated. Thanks
86 C5 Auto BII, FS Axles, 37 Swampers
you will also need to use a torque convertor from a c-4 since the c-5 has a lockup feature, and the c-4 valve body will need to be used, again to by pass the lockup functions in the c-5 valve body. i simply used a complete c-4 i had to disassemble the trans and replace the output shaft and extention housing from the c-5 in the c-4. you can see detailed pics of my conversion here http://www.cardomain.com/ride/1804091
mike
mike
