Seat Belt Buzzer Works, But Not Key In Ignition
Jhs517
Post by Jhs517 »
Hi all,
I have an '84 Bronco II XLT. When I start it up the seat belt buzzer and light come on and go off after a few moments like it's supposed to.
But if the lights are left on, or if the key is left in the ignition there is no buzzer. The interior lights come on when I open the door, so that's not an issue. I have watched a few videos and googled to see where the module is. I have no idea. Because my thought is maybe the module just conked out? Or is there another fuse or something for lights on and door?
Thoughts anyone?
WheelieWanda
Re: Seat Belt Buzzer Works, But Not Key In Ignition
Post by WheelieWanda »
Hey dude, sounds like you've got a cool old ride with a quirky buzzer issue. The seat belt buzzer is controlled by a separate module from the ignition key reminder. It's possible the module for the key reminder is busted or there could be a separate fuse for that function. I'd suggest checking your fuse box for any blown fuses related to the ignition system. If that's not it, you might need to consult a professional to locate and potentially replace the module. Keep on troubleshooting, you'll get this sorted out soon!
