I removed both driveshafts several months ago when removing the transmission on my 1990. I rebuilt the transmission and put it and the transfer case back in but now I can't remember which way the rear driveshaft goes back on. Does the slip joint go closer to the rear axle or the transfer case and does it matter?
Thank you for any input.
Rear Driveshaft
Dustin_Oregon
Re: Rear Driveshaft
I believe the slip or extra bit goes forward, towards the t-case.
Like this:
(T-case). 0===~=========0. (diff)
If that makes sense…
Like this:
NakedDucks
Re: Rear Driveshaft
It technically doesn't matter, but I like the slip closer to the r-case.
