Starting Bronco II after 5 years
briese87
Post by briese87 » Sat Feb 02, 2019 7:09 pm
A buddy at work is practictly giving away a bronco 2. I want it but have to get it running. I would appreciate input. I know very little about the truck.. I do know it ran fine when he parked it. it's a 2.9fi 5sp 4x4 and low mile ( 50k range) and in good condition! It's a steal. But it hasn't run in 5ish years. I need to get it running to get her home.. like 10 miles.. I know I need to drain old gas and new battery. There are lots of things I will work on when I get her home just hoping all you wise people won't tell me I need to change the oil, coolant, etc... It's been in a garage but not heated.. my temptation is to fire her up (if its that easy) and bring her home. All wisdom is appreciated. Thank you.
Sent from my SM-S727VL using Tapatalk
broncofan
Re: Starting Bronco II after 5 years
Post by broncofan » Sun Mar 03, 2019 10:36 am
You should want to change all the fluids after sitting that long anyway, if she starts let her run for a bit, if not see below.
Injectors are probably bad after sitting. Check to see fuel pressure first, turn key on, listen for pump, Schrader valve for injectors by throttle body. See if fuel comes out. Make sure keys off first lol. fuel squirts out, it may start and run poorly lol.
Post pics too lol.
86bronco2sanDiego
Post by 86bronco2sanDiego » Fri Mar 06, 2020 10:18 am
I know this is an old post, but I just had to respond. I had the same bronco , 86 it set for 10 years! I put a new battery in it and it literally started the first key turn. It had been outside, with a car cover. I think your truck probably would have started with a new battery and some new gas. just my two cents. I was shocked.
Currently in a full restoration can't believe I let it sit so long..
robertoinmexico45
Post by robertoinmexico45 » Sat Mar 07, 2020 11:30 am
First disable it so it cannot start. Pull the wire to the dizzy. Check If there is fuel and if it has that horribie smell drain and add fresh fuel.. Make sure there is oil in the crankcase and all under hood fluids are ok,. Do a visual check that all the components are there and not disconected. Charge or jump the battery. Spin the engine with the dizzy disconnected for maybe a minute or more to circulate oil to the critical parts. Get in and stomp on the brakes to be sure the get hard.Might take a bit to get the fuel up. Take her home and get to work...w the original date.
Ha aha ha just saw the original date !!! If you are still around give us a report
