The new family suv(86 bronco II)
86 Bronco 2 just after it came home.
- Attachments
- Picture 2311.jpg (20.57 KiB) Viewed 51607 times
Re: The new family suv(86 bronco II)
The coil spacers and shackles. They have to come off the camber is too far out to align.
Those car tires had to go!! Bridgestone duellers are much better!!
My camber is off 1 5/8 inches both sides as checked with a level and tape measure. WTF???
Possible wheel bearing issues!!! I had the same issue
Mudhog1977
Just get it aligned, anytime you alter your suspension it gets outta whack, easy fix
Mudhog1977
Thanks. We love this truck. The alignment shop is not worth a crap. DO NOT Use B & B Tires in Hohenwald, TN they aren't worth a shit!!!! The tires both wore out on the inside. They fixed it and offered to take $5 off a new set of tires. Really? Your incompetence ruined a good set of tires.
Did you at least get a refund on the alignment? seeing as how they did not align the car i would cite services not rendered.rusty7983 wrote:Thanks. We love this truck. The alignment shop is not worth a crap. DO NOT Use B & B Tires in Hohenwald, TN they aren't worth a shit!!!! The tires both wore out on the inside. They fixed it and offered to take $5 off a new set of tires. Really? Your incompetence ruined a good set of tires.
