How do you replace the headlight assembly??
varadarcop
Been searching the internet for days, trying to find instructions on how to change the headlight assembly on a 1989 Bronco II... Does anyone know?? I've got the part, need to know how to put it in!
cheesydoesit
Re: How do you replace the headlight assembly??
the headlight assem. can be removed by taking out the screws on top of of the light under the hood,disconnect the bulb from the back of the ligh/ you'll need to take off the grill as well. it's pretty straight forward.
it's easy on an 89. lift the hood and on the back side you will see were the bulb goes in. disconnect the bulb connector and twist the black ring to remove bulb. note that te bulb has to go in a certain way
ooh nevermind I thought you were just changing bulbs not the assy
