86 B2 fuel guage/sending unit?
danboy282
Post by danboy282 »
the fuel gauge on my 86 B2 Eddie Bauer doesn't work. Is the sending unit in the fuel tank? If yes, do i have to drop the tank to get to it?
Thanks again
Mud Addict
Re: 86 B2 fuel guage/sending unit?
Post by Mud Addict »
Drop it, or cut an access hole in the floor :redneck:
dgl6y6
Post by dgl6y6 »
did it stop working suddenly or start reading too low then finally quit? check the wires on the back of the gauge cluster for a bad connection. while thats out put an ohm meter on the wires and measure the resistance to the sending unit. if i remember it should be 10 ohm for full tank and 70 for empty. i could be wrong but if its really high or reads as a broken circuit then ur sending unit is bad.
