starter problems
starter problems
Re: starter problems
I have the same exact problem.
I have tried different bell housing, starter, starter drive gear and flywheel. admittedly both flywheels were used.
I have come to the conclusion that it is the flywheel. Just because there are no missing teeth they still could be not as high as the other teeth, causing a flat spot.
I have been able to get mine to start by putting a washer on the engine side of the bottom starter mounting bolt, between the starter and the bell housing. This tilts the starter enuff to engage the shorter teeth.
'84 Bll 2.8L w/ duraspark, rv cam
TK5, 31x10.50x15
TK5, 31x10.50x15
i had the same problem in my 84. i replaced my starter, soleniod, and all the wires, come to find out i had a batter that didnt get enough cold crank amps to start it. changed my battery and never had the grinding problem again
