set my b2 on fire
label_sk8er16
set my b2 on fire
Post by label_sk8er16 »
So the other day while i was on my way to work i notices a strange smell, i pulled over to investigate and found the under carriage of my 88 b2 engulfed in flames, :eek: The cat was plugged and started glowing orange. The hot cat set a greasy cross member on fire, After battling the blaze with windshield washer fluid i started it back up, it ran fine but now it wont shift out of 1st gear. :mad: with no apparent damage to the outside of the trans, i'm not sure what is wrong. :wtf: i don't have much time to tare into it, i was wondering what some possible problems could be.
thanks, :smilie: Ben.
Re: set my b2 on fire
Post by tekatlarge »
You never said what type of trans you had a stick or an automatic!
If it is an automatic you could have melted the vacuum hose to the modulator valve. Ya could have cooked a shift solenoid or many other things
label_sk8er16
o my bad.. its an automatic, 2.9. that was a hunch, i thought i could have melted a vacuum hose. i didn't look real hard but couldn't see any that were cooked.
