Trigger_2001
Posts: 44 Joined: Fri Sep 10, 2004 9:36 am
Post
by Trigger_2001 » Fri Nov 05, 2004 9:45 am
There is a grinding sound in my tranny when my clutch is let out on all gears. The tranny guy said it could be the front bearing. Could be costly. anyone have a 5 speed manual for an 88 b2 laying around????
The Bronc Rider (is only 15!!)
b2binbad
Posts: 232 Joined: Fri Jun 11, 2004 7:40 pm
Post
by b2binbad » Fri Nov 05, 2004 9:58 pm
Sounds more like a clutch problem vs. tranny.
OCD4B2
Posts: 227 Joined: Fri Sep 10, 2004 5:10 pm
Post
by OCD4B2 » Sat Nov 06, 2004 12:34 am
sounds like a clutch problem, otherwise it would be like mine, drive shaft is going bad.
MXjunk127
Posts: 40 Joined: Wed Apr 21, 2004 5:10 pm
Post
by MXjunk127 » Sat Nov 06, 2004 12:44 pm
I had the same thing on mine, but i never fixed it, and swaped to an auto trany instead. Its the clutch.
My little pony
Posts: 26 Joined: Fri Jul 23, 2004 6:32 am
Post
by My little pony » Sat Nov 06, 2004 1:19 pm
I would have to say it sounds like the release bearing, and if you have to replace it you might as well replace the clutch and press plate when you have the trans out.
God forgives, Rocks Don't.
Trigger_2001
Post
by Trigger_2001 » Tue Nov 09, 2004 9:43 am
Wouldn't the front main shaft bearing grind all of the time? I noticed that if you let off the gas in 3rd gear you can't hear the grinding sound.
