Dana 35 Axle Swap Complete / Now ? About wheel spacer....
madmax
Post by madmax »
So i got my Dana 35 axle swap done today on my Bronco 2, and a alignment. But now my front tires stick out more than the rear, does anyone know the size wheel spacer i need to order to even out the rear? Also my tires now rub on the front bumper, is this due to the fact the axle is wider and the tires stick out more?
04sd
Re: Dana 35 Axle Swap Complete / Now ? About wheel spacer...
Post by 04sd »
I'm guessing you're running wider than stock wheels on the front?
Swap in an 8.8 rear and it'll get it more in sync with the wider front.
Bill
1990 BII, 4.0, (sold)
2005 F150 SCrew
'84 Ranger under construction
04sd wrote:I'm guessing you're running wider than stock wheels on the front?
the 35 is about 1.5in wider that the 28.the 8.8 will work cause its 1.5in wider than the B2 7.5
1.5in spacers
