can anybody help me!! i don't know haw to remove the two bolts at the rear of the skid plate at the rear bumper i removed the two front ones fine but i cant find where to remove the others.
any pictures would be very helpful
1987 Bronco ll Skid Plate Removal
Re: 1987 Bronco ll Skid Plate Removal
You have to look in the bumper. There are Two bolts that extended into it. To get to them from the underside you will need to look at the rear of the plate and will see two holes on each side. From the top of the bumper you will need to pop out that black plastic piece before you can get to them. Hope this helps.
hey thanks ill try it
