4.0 in ranger help plz
can u put a explorer 4.0 into a ranger? if so would it be good to put in a body lift in?
Re: 4.0 in ranger help plz
You need to use a 4.0 trans with the engine. Putting in the engine is the easy part, wiring is a little more difficult. No need for a body lift.
Bill
1990 BII, 4.0, (sold)
2005 F150 SCrew
'84 Ranger under construction
2005 F150 SCrew
yes it will go in.
your going to want all the doners wires tho. and computer.
a body lift is not needed. it will give you a little more room with the transmission and the fire wall tho
