Valve Cover Gasket Replacement
303lithgow
I have the pleasure of replacing the passenger side valve cover gasket. Any good hints?
1990 Bronco II, XLT, 5 speed
1970 F250 Camper Special
303lithgow
Re: Valve Cover Gasket Replacement
Actually I have to unhook other items first.Ranger Dave wrote:take the bolts out first
Pass. side is the easy side. Remove bolts and hold down spacer (note that there is different spacers for the top and corners) clean the heck out of everything, even the holes. Make sure V/C is flat. Put gasket on V/C side with gasket cinch or spray adhesive. Assemble in reverse order. Oh, put a dab of silicone where the intake manifold meets the head. Tighten bolts about a week later and every oil change.
303lithgow
Thanks, I didn't notice the differance in the spacers and lined them up when I was cleaning them. I dropped one taking the v/c off and it took me an hour to find it. Just glad I didn't didn't fall into the head.drofman wrote:Pass. side is the easy side. Remove bolts and hold down spacer (note that there is different spacers for the top and corners) clean the heck out of everything, even the holes. Make sure V/C is flat. Put gasket on V/C side with gasket cinch or spray adhesive. Assemble in reverse order. Oh, put a dab of silicone where the intake manifold meets the head. Tighten bolts about a week later and every oil change.
I did the pass side today and thought it was going to be the hardest because of the a/c. It took me six hours! Bet I could do the otherside in two.
The real question is how many beers in 6 hours. That's the way I judge my jobs at home. Warranty used to pay 1.2. CP 2.5. I should of told you it may be easier if you pull the ALT.
1.2 for both
303lithgow
drofman wrote:The real question is how many beers in 6 hours. That's the way I judge my jobs at home. Warranty used to pay 1.2. CP 2.5. I should of told you it may be easier if you pull the ALT.
No beers but a dozen cups of coffee and I have a TV and sofa in the garage. Its not like I'm going to get fired if I get caught watching TV and drinking coffee.
I went to the bone yard today for a few things and noticed some 2.9L engines had differant keepers in the corners and some didn't even have any anywhere.
The gaskets that I took out were semi-brittle and crumbled easily. The leak wasn't too bad but then one day it really was leaking. I've only owned the B2 for a month or so. The good news is it doesn't leak anymore.
It's nice to have a ride that doesn't leak BP. I just did pistons in my Sons jetski and it took 4 beers to rip apart and 6 to put back together and it runs
. I'd have to clean the garage to fit a tv and sofa. I need to get rid of some stuff!!! It's good stuff and as soon as I get rid of it I'll need it
