Trouble with my 1990 2.9
I cant seem to get my 1990 bronco II to start. I have replaced the distributor but I dont seem to be getting fire. I put a coil on it but still nothing. Any ideas?
Re: Trouble with my 1990 2.9
Test light to the - side of the coil while trying to start it. The light should pulse on an off. If it does not, could be Dist. not turning, computer issue, computer relay/wiring issue, TFI problem, rotor broken/missing, broken/unconnected coil wire. or wiring between the Dist an coil, or defective coil.
