I have a loud thump when going down the road...well actually it happens most anytime.
when coming to a stop and just after taking off (but not every time) going downhill, uphill.
It shakes the vehicle at times and at other times it is mild.
The trans shifts thru the gears just fine. It's an automatic by the way.
Any ideas?
thanks!
a loud thump 88 xlt b2
Re: a loud thump 88 xlt b2
My Best unemedjucted Guess is Bad U joint on the drive shaft. If you have the Tulip joint (cv) I will bet ya it is Junk..
Thanks!
I'll look at it.
I'll look at it.
check rad arm bushings
upon further inspection (more driving) it seems to be coming from the drivers side front.
it even actually seems to jerk (not the jerk behind the wheel) the vehicle at times, especially if it is under load.
I'm sure those tidbits of info help!
Thanks
Thanks
