Rear Drive Shaft PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!
PLEASE HELP!!!!!!!!! I have a 1986 ford bronco II with a broken u joint and yoke for the rear drive shaft the shaft is still good just the u joint and yoke is broke. I have seached everywhere for a new one even asked auto stores (auto zone advanced auto oreilys) i think i might have found one at a junk yard but not sure. Can i pull one off another year behicle or anything what are my options here i just want to get back into the mud and need 4X4.
Re: Rear Drive Shaft PLEASE HELP!!!!!!!!!!!!!!!!!!!!!!!!!
I would imagine that if the donor vehicle has the same tranny (manual or auto) and the same flanges the drive shaft should work. As far as the yoke, you should be able to take one off the same donor as well. What happened to the yoke? Did it get loose and then strip the splines? I hope it only ruined the yoke and not the pinion splines. Got a pic?
