My breaks have all but quit stopping the B2. At first I thought it was due to fluid levels - but on checking, the levels look ok although the fluid is turning black...
As I was driving home today, I noticed that when I when I braked (while the engine was running) there is an audible hiss sound coming from the area of the pedal. As soon as I stop the engine, the hiss gets louder for a second, then stops completely as the pedal suddenly feels strong again (if that makes sense).
Would anyone have any idea why this is happening?
Hissing noise coming from break pedal
1984 Ford Bronco II
2.8 v6 Engine
Manual Shift 5 speed
4 inch suspension lift
2.8 v6 Engine
Re: Hissing noise coming from break pedal
Sounds to me like a ruptured power brake diaphragm. The engine vacuum is routed to the brake booster to give you power brakes. If you hear hissing then it is leaking. replace the booster!
thanks for the quick reply -
so how big a job is that...
1984 Ford Bronco II
2.8 v6 Engine
2.8 v6 Engine
Probably about an hour of labor..
Want to make an Appointment? he he
given the state of my break pipes - Im very doubtful that they would survive being disconnected. Ive also got a broken bleed nipple on the back passenger wheel - so Im guessing that would need fixed too.
All in all, Im feeling this might be the end of the road for my B2 as I lack the time and resources to repair it
1984 Ford Bronco II
2.8 v6 Engine
2.8 v6 Engine
