starting issue
chucknti
starting issue
Post by chucknti »
i just finished rebuilding my bronco put in motor, never ran when i got it. i hooked up the starter and battery cables and went to crank it, and took the key out and it still cranking by itself. put on a new relay, same thing please help dont know what to do
greenmachine89
Re: starting issue
Post by greenmachine89 »
I would check the ignition switch sounds like the guts are hanging up. if it keep going even when the engine is running then it sounds like your starter is hanging up on something. or the soleniod isn't working
chucknti
Re: starting issue
Post by chucknti »
i did a frame off resto and forgot to reconnect all the grounds :D ,
thanks anyway
