I have a 86 bronco 2. The engine comes up to temp just fine. Cant seem to get heat outta the heater? Is their a heat control valve or just the blend door? Maybe plugged up heater core? Just replaced the thermo with a 195. Any info would be great.
Thanks
Jeffb3041
Heater help!!!
Re: Heater help!!!
grab the heater hoses when the engine is up to temp, make sure there both hot.one maybe a little hotter than the other. the fan work??
Re: Heater help!!!
One is alot warmer than the other. Plugged heater core? Is their a heater temp valve? or just the blend baffle?
Thanks
Jeffb3041
Thanks
Jeffb3041
Re: Heater help!!!
Yeah, I'd check the heater core, simple to pull and while you have it out you may also pull the blower motor (also easy) and see where your leak is coming from... As stated in your other post, this could be because of a stopped up drain in your vent system or it's less possible that you have anti-freeze leaking into the vent.. Either way, this is a good time to get it all under control.. Clean out all the debris, check your dash controls, drain etc.....
Re: Heater help!!!
jeffb3041 wrote:I have a 86 bronco 2. The engine comes up to temp just fine. Cant seem to get heat outta the heater? Is their a heat control valve or just the blend door? Maybe plugged up heater core? Just replaced the thermo with a 195. Any info would be great.
Thanks
Jeffb3041
what leak??
UPDATE Re: Heater help!!!
The heater coer was plugged... That was easy!!! The leak ended up being on the inner femder on the passenger side. Got it all sealed up.. Thanks for everyones input.
86 Bronco II
97 F-350 power stroke crew cab with banks
78 king cobra mustang 302
86 Bronco II
