transmission pisses out fluid
my auto trans pisses out fluid when it gets tooooo hott and leaks a little when the fluid is just a little hot... why does it do this?.. i have a aftermarket trans cooler, and im running 33" tires i know thats what makes it hot...
87 bronco 2 4x4
4 inch suspention lift running 33's
Re: transmission pisses out fluid
If the trans is pissing out the front behind the converter you are about 1 step from failure.
I assume your talking about the famous A4LD! If this is correct then this is what is happening.
The A4LD had a problem with the bell housing and front pump and seal... The quick explanation is due to design details and manufacturing procedures. basically if the front bushing in the trans is worn it allows oil to get behind the oil seal and literary push the seal right out of the trans. Also if the bushing is worn out the neck of the torque converter will wobble slightly causing accelerated wear on the front seal making the problem worse.
The "Fix" is not a backyard or front yard fix. The trans is pulled and you have to have some machining done on the bell housing but it requires special setup and tooling to do. There use to be quite a few shops around that could do this but they are a numbered few that can do this right.
Summary: I am just generalizing above there is more to the fix but I would have to go find my papers and review them to get all the details. Basically replace the trans with a C4 or go with a stick or find a "GOOD" trans shop. Find one and explain the problem to them. If they know their stuff they will know exactally what will need to be done. It might be pricey but once done and some other mods and the A4LD could be as good a trans or better than a C4 and you will have OD.
thanks... yes its the A4LD it has been doing this for such a long time now i dont drive it far just to and from work and to friends and stuff.. i just keep topping it up and with the trans cooler and the cold weather right now its not to bad.. i only drive it the winter as my daily driver... it just has to last me throu the rest of this winter.. then i swaping in the drivetrain form a explorer
87 bronco 2 4x4
