5.0 Install
Re: 5.0 Install
That's the only number on it. Is there any other way to tell.
Re: 5.0 Install
the difference is in the gear. one is steel and the other is cast i think. but there is a difference. did the oil pump shaft fit ok??
Re: 5.0 Install
Reman.; w/Module; w/Cast Iron Gear; Distributor is supplied with module;Cast Iron and Steel Gears are not interchangeable and will cause severe damage.
Re: 5.0 Install
you have ta know if that motor is a real GT one. if it is than go get a rebuilt GT dist.
Re: 5.0 Install
do you know what the firing order is for your motor??? theres 2
Re: 5.0 Install
I got the engine with all that installed. The intake wasn't on it, so I don't know if it was carbed or injected. That's the issue.
Re: 5.0 Install
In earlier posts we figured out it was a HO 87 bronco motor.
Re: 5.0 Install
onewontwo wrote:In earlier posts we figured out it was a HO 87 bronco motor.
HUH
get the casting numbers and date code. the date code should right above the casting number
Re: 5.0 Install
Yeah, go a couple pages back. I have all that information posted. I believe your the one that said it was from an 87 bronco and from my understanding that it is a HO motor.
Re: 5.0 Install
what number/letter in the casting number says its a bronco engine?? the "T"= truck
Re: 5.0 Install
That's what I thought. The guy I got it from said it was from a mustang, but I posted the casting number and someone said 87 bronco. So I never found out for sure.
Re: 5.0 Install
there is no way to tell if it came out of a bronco. its a truck engine. the intake you have is not a bronco one. this is the bronco intake
Re: 5.0 Install
you need toonewontwo wrote: So I never found out for sure.
Re: 5.0 Install
The intake is from a 91 mustang. I'm almost positive it's an 87 bronco.
