Working on my 84 bronco II 4x4 with automatic hubs.
I am trying to reassemble; I am stuck on the cam assembly piece. I am having trouble getting the cam to slide onto the spindle:
I have lined up the center of the spline keyway with the closest hole/slot on the bearing adjusting nut and then I try to slide the cam assembly with it's little slot into the above mentioned spot.
any ideas?
thanks
Need suggestions on front hub assembly
CarbedNotch
Re: Need suggestions on front hub assembly
If it jams, force it.
If it breaks, it needed replacing.
vabronconut
wishi could help, but other than tearing the axle apart in a extremly crude way i have never worked one these hubs.
