bronco 2 slow to start....
MONTANA
Post by MONTANA »
my b2 1986 all of the sudden is slow to start, cranks quite a few times before it fires, then idles a bit rough.....under throttle it seems fine...???
vabronconut
Re: bronco 2 slow to start....
Post by vabronconut »
MONTANA wrote:my b2 1986 all of the sudden is slow to start, cranks quite a few times before it fires, then idles a bit rough.....under throttle it seems fine...???
DAMN DUDE WHAT DID YOU DO TO THAT THING ???? :eek: could be the timing is off, or fuel starved with all you got goin i would have to tinker with it to figure it out
MONTANA
Post by MONTANA »
so got it figured out...new ign.coil,' dist.cap, rotor,high pressure fuel pump....now it's back to normal. i do have the weird black fuel filter that seems to be kinda rare, ...and the "tick"..is ever present, but from what i'm reading it's pretty normal for the 2.9..but open to any ideas!
i do have a question, can i swap my anto hubs for manuals? if so, will i have a 2wd low range gear when the hubs are not in but the 4wd is on?
