Long time mustang man,just got bronco 2, have questions!
I have long been into mustangs and pretty much everything Ford, i have owned 5 mustangs, but the whole bronco2/ranger thing is new to me. Heres my question, i plan to do a v-8 swap with a 347 stroker with a c-4, i was planning on putting a 8.8 from a ranger and dana 35 for the front. i have the complete 5-lug set up from a 1995 mustang gt with brakes, is there any way to adapt the brakes from this on to my bronco 2, both use the 8.8 inch rear, and im not at all familiar with the dana 35. And is there a company who makes aftermarket parts to beef up the dana 35, any help with this would be appreciated
Re: Long time mustang man,just got bronco 2, have questions!
allot of your questions i have not idea. as far as mustang rotors on ranger, well the pattern is 5 on 4.5 for the ranger so if thats what you got it should work. the axle shafts will not interchange as they run different spline counts, but a complete 8.8 swap would work great. the front dana 35 no the parts will not interchange on the rotors or hubs due to the 4wd. i would ask the guys at www.therangerstation.com if they know anyone who makes aftermarket for it.
The front rotors and spindle from a 2wd mustang wont fit a 4x4 bronco.
Do you already have the 8.8 from the Ranger? If not I would go with the explorer 8.8 because they had 31 spline count were the Ranger's I think were only 28 spline it's a little bit more work but if you can weld then it's not a problem.
'89 Bronco II
'03 GMC Sierra Z71
'89 Bronco II
'03 GMC Sierra Z71
