Just Thinking....
Just Thinking....
Ok, I HAD a 3.5" TTB lift and I liked the height. Now If I go with a 3.5" duff for EB and a 5.0L how much over STOCK should I get (approx)? I dont really want to go too much over what I had before the swap. Any ideas? If I got stock height EB coils and used them would I get enough lift? Maybe its a stupid question, but I am tired....
with stock springs I have heard people say 3" of lift. they are stiffer so I dont think it would sag to much less then that. if you go that rought you will not have the flex that the duff springs will give you.
I can't remember if people are getting 6" with the duff 3.5's or not but if thats the case I would think that would drop an inch or maybe 2. just because of the weight of the motor so 4"-5"
reguadless of the height I would go with the duff springs and just adjust the rear to match the front.
I initially got about 8" of lift, it was 4" taller than my 4" skyjacker lift. I believe it settled to about 6". You need that much lift for clearance between the axle and engine crossmember. As it is, I had to trim the cossmember for clearance. Or I suppose you could make use of some agressive bump stops, but that defeats the purpose of the swap.
Trust me though......you want every bit of lift the duff 3.5's provide. It will look fine with your tires, and will flex awesome! :cool:
Bob Myers
Post by Bob Myers »
THis is with 3.5 WH springs, one coil cut off. 32" tires just don't fill the voidImage
92 XJ-wifes toy
Have you built a wristed arm yet?. You should be able to stuff a tire up into your fender.
So any difference in WH or Duff coils other then the $2? I would prefer to stay duff, unless the WH is that much better. Their website claims that its very flexy. The duff $117 is very tempting tho.
Nobody has a comparo-chart of the duff, wild horse, and i think another coil used and new. it's on the link section. i was checking it out for my spring's but im just gonna go with whoever makes 5.5" springs.
Ok...that's embarrassing....I was looking all over for that on the net :rolleyes:
http://www.vintagebronco.com/coby/image ... ildata.htm
To answer you question again phillippi.....the main difference is price and color among the popular springs.
You're a little hung up on the TTB stuff where the quality of coil varied greatly among mall kits.
wilber
Post by wilber »
bogger is runing stock 150 coils in his read chop top, if you have some fab skills, i would make a new crossmember for the engine, and get rid of that low hangin one
Ok now thats what I wanted to hear. I know of the crap that was out there for TTB and didnt know if that same crap was out there for the SAS coil. If that is the case then Duff all the way. I didnt want some stiff coils that would jar my teeth loose.
Also I have a line on some used Duff 26" shocks. Are those duff shocks any good? They dont seem to be the long travel shocks but the other they sell for the EB. Any insight on them?
anyone use these?? is the 26" long enough?
jollymon
Post by jollymon »
Nobody wrote:Ok...that's embarrassing....I was looking all over for that on the net :rolleyes:
Been trying find this info... searching led me here, but that linky no worky :frown: Anybody know where I can find Coby's coil spring comparo stuff in an active link, etc.?
Thanks much!
-Trav
That link died shortly after it was posted here. All coby's picture are gone off that website now :confused: Best bet would be to track down his e-mail and contact him directly.
jollymon
Post by jollymon »
AH, I see... thanks for the quicky reply :cool:
I'll continue my "quest"
