distributor question
I'm doing away with my stock ignition..(DARN YES)..Is the spacer inbetween the dist. and the cap swappable when I change to my pinto dist. I bought a 2691 from advance and it didn't come with one? Is this a no brainer?
I May get Lost But I Don't Get Stuck
84 BroncoII, Locked, Winched, Big Tires,
It won't fit without it??
After finding out that the cap adapter is hard to find for a stock ignition Advance doesn't offer one for the 2691 distibutor either, However...
When changing the 84 Bronco II to a duraspark ignition I've learned that when I ordered a distributor, Advance Auto part#30-2691 (single vacuum line) it doesn't come with a cap adapter to fit the larger cap. Advance doesn't list a cap adapter for that distributor. The cap adapter part # FR109 which fits about 20 other fords, will fit #2691 distributor. Along with those you will need a rotor#FR106 and a cap#FR121. The distributor and cap adapter both had to be special ordered.
I put this on your other distributor post, but I think it'll answer all your questions:
http://home.att.net/~performance2800/Co ... Specs.html
