At the moment I have 2 Bronco II's, one of which I am considering doing a 302 conversion to. The candidate for the conversion is an '84 4x4 2.8 Bronco II with a 5 speed. It is currently not running and I really don't want to put any money into the existing 2.8 setup. It has been sitting for some 7 years but is in great cosmetic shape outside (garaged). I have researched this for quite some time and still have some questions. I know that my existing 5 speed cannot handle V8 power, that being said I am unsure of the transfer case in my truck, I don't know what type it is and would love to know how to identify it. What I'm driving at is:
A: Can someone tell me what type of transfer case is in my Bronco II based off of year and power train config?
B: What would be my best bet for a manual transmission configuration? I would prefer a 5 speed if possible ( considering a 5 speed from a Mustang if that will work)
C: If my transfer case will work what adapter will I need to mate it to the 5 speed.
D: Regarding the front and rear axles, would it be ok to use the stock ones for now? I know the original rear end blew out some time ago and was replaced I will need to look and see what is in it now. I know for sure it is not the same type that was originally in it.
Overall the article on the front page was great for shedding some light on what I will be getting myself into, it just happened to leave me with some nagging questions I have been unable to answer for myself so any help is appreciated.
A few 302 swap questions.
Re: A few 302 swap questions.
Borg Warner 1350. They are decent transfer cases that can survive behind a V8. However if you are buying an adapter, there are better options out there.JRR1285 wrote: A: Can someone tell me what type of transfer case is in my Bronco II based off of year and power train config?
The mustang T-5 isn't really a good option. Adapting a transfercase to it is very expensive, and the gear ratios are not good. The ZF-5 is a decent 5 speed ford tranny. Then there are the NV4500 and NV3550 or something like that. But still those are hard to find and expensive.JRR1285 wrote: B: What would be my best bet for a manual transmission configuration? I would prefer a 5 speed if possible ( considering a 5 speed from a Mustang if that will work)
If you are set on having a manual transmission, it's hard to beat the NP435. It's a 4 speed with a granny low.
JRR1285 wrote: C: If my transfer case will work what adapter will I need to mate it to the 5 speed.
As mentioned above, if you have to buy an adapter, might as well research transfer cases and get the one that you want and works best with your transmission selection.
I ran my stock rear end for awhile. If you go easy, there's no reason you stock axle won't hold up for awhile. Definately plan on swapping them out though.JRR1285 wrote: D: Regarding the front and rear axles, would it be ok to use the stock ones for now? I know the original rear end blew out some time ago and was replaced I will need to look and see what is in it now. I know for sure it is not the same type that was originally in it.
