Has anyone ever tried these???
I was wondering if anyone has used these to get the same wheel pattern front and rear? They are from www.performancewheel.com. These would be use to make my 7.5 5 on 5.4 ot 5 on 5.5.
I have seen those on a full sized cheby with 20"s and I didn't like the way they looked. the wheels didn't line up right, to make enough contact with the rotor. the ones I saw were aluminum,
. I jnow they would give you a temperary fix to the lug patern problem but I see them as a weak link. do you really want your wheel held on with an aluminum plate? just something to think about.
how long will you be waiting befor you put in the 8.8?
you might want to think about doing the front and rear at the same time. the only thing involved is a driveshaft alteration and moving the leaf perches to get the proper pinion angle and leaf width.
Im thinking that I will keep the 7.5 for a while (like a couple of years) as I dont get on the gas that often. I want to keep a good locker (detroit in my 7.5) until I can find a good 9" or 60 that I can have cut down so its not soo wide. My mind keeps going back and forth on the FS axles right now....
