broncoii33
Posts: 4 Joined: Wed Apr 18, 2007 5:29 pm
Post
by broncoii33 » Thu Apr 19, 2007 4:22 pm
I have a 89 Bronco ii 4x4, auto trans., 6" susp lift on 33's. I used a Double Carden Drive Shaft from a 85 Bronco ii 5 sp. Transfer case housing broke at the output shaft. I would like some input since I have never had this problem with my 85 ranger 4x4 with the same lift? Please give feedback. I need some suggestions before replacing parts
Hair
Posts: 26 Joined: Sun Sep 25, 2005 6:16 pm
Post
by Hair » Thu Apr 19, 2007 6:42 pm
Mine, A 1987 Bronco II did the same thing
it was axle wrap that caused it to happen!
5" of lift, 3" leafs and 2" blocks
I put on Anti wrap/Traction bars and havent had the problem since
Bob Myers
Posts: 274 Joined: Sat Apr 24, 2004 6:33 am
Post
by Bob Myers » Sun Apr 22, 2007 8:12 am
electric or manual case? I have several rear case for electric
92 XJ-wifes toy
Posts: 743 Joined: Sat Jan 01, 2005 8:10 pm
Post
by ranger5.0 » Sun Apr 22, 2007 9:52 am
Did you have your rear driveline extended for the lift? I have had to long of a driveline punch through the t-case under full compression.
