Wanted: Camedia Master 2.5
Anyone out there have an Olympus digital camera that came with the Camedia Master 2.5 software? Would have been from the ~2001 time frame.
bartmantom
Post by bartmantom »
Yeah, I saw that. Those are just the updates for the program, which is what I am ultimately after, but I still need the original install first. I have version 2.01, but it's not fully XP compatible.
My camera is the C-3030. It's been an awesome camera, but unfortunately, you need the software to change some of the settings on the camera, including the date!
i think i got just what you need let me check if so you can burn a copy. i should be around the house this weekend.................... okay i have Camedia Master 4.1 let me know if you can use it. i wont be around till thursday afternoon cuz i'll be stuck on the boat till then.
I have 4.1, but you cant' adjust the settings on my camera with it. Thanks for the offer though!
2.5 where are you!
Post by EBSTEVE »
If you have 2.01 can you update it to the Camedia Master 2.5? Here is the page I found http://www.olympusamerica.com/files/Win_XP.pdf and the link that is the "Windows XP Compatibility"
http://www.olympusamerica.com/files/cm251_update.exe
But to be honest, your the nerd :finger:
No can do! Gotta have 2.5!
Post by EBSTEVE »
Go to the Russian download site to get a free copy of the Camedia 2.5 software from (you do read Russian don't you? if not click on the blue Russian text)
http://www.nix.ru/download_from_ftp_ext.html?id=4303
The software is stored in a RAR file type (like a zip file but different)... so you will need WinAce (or similar) to extract the files... a free version of WinAce extractor can be found at:
http://www.winace.com/files/xace26.exe
Use the WinAce software to extract the .rar file into a set of files in a folder somewhere on your desktop. Then go into that folder and run the Setup.exe file. When that finishes, you will have Camedia 2.5 installed. Since you're running XP, you will want to also run the 2.5.1 update available from the olympus site
Hopefully that's all the infomation you need or your on your own. Please don't tell anyone that I read Russian I already get enough crap about the "normal" stuff I do.
I wish I knew russian... That language sounds very cool.
Post by EBSTEVE »
so
:foot tap: :foot tap: :foot tap: :foot tap: :foot tap: :foot tap:
Gimme a break, some of us work for a living.
It appears to have worked! Not real crazy about where it came from, but it will work. Seems the same as 2.01 though, so I'm not sure what changed. :confused:
Post by EBSTEVE »
Nobody wrote:Not real crazy about where it came from:confused:
Got something against the Russians?
well considering they are right up there with china for viruses and spam......
I am feeling a little tension against the Russians here. :redneck:
BDEUCE
Post by BDEUCE »
hey brother, easy on the russians...(whisper) they're my neighbors... :cool:
