pigmy pony
Posts: 39 Joined: Sun Dec 17, 2006 8:55 pm
Post
by pigmy pony » Mon Feb 12, 2007 7:21 pm
I have an 86 2.9 b2. The guy who owned it before me took the air cond out. The condenser is still in there and I swapping the radiator because I am turning the truck into a manual trans. Is the condenser useless without the air conditioning. Just wanted to make sure before i riped it out.
thank you
Momentum and wheel spin
deathmetalandrez
Posts: 23 Joined: Sat Sep 02, 2006 1:04 am
Post
by deathmetalandrez » Mon Feb 12, 2007 7:35 pm
toss an empty fire extinguisher in there and use it for portable compressed air
I currently own 4 bronco 2's. Three of them are 89' of which two are 4x4 and love em. The other is an 85' 4x4 5-spd
Posts: 588 Joined: Sun Apr 18, 2004 10:41 pm
Post
by Rockcrawler » Tue Feb 13, 2007 2:16 am
the condenser just works as part of the AC if you dont have AC anymore its just taking up space.
Limited
Posts: 62 Joined: Thu Oct 26, 2006 10:05 am
Post
by Limited » Tue Feb 13, 2007 11:05 am
you can use a fire extinguisher for OBA?
Rectum, damn near killed em
Bob Myers
Posts: 274 Joined: Sat Apr 24, 2004 6:33 am
Post
by Bob Myers » Tue Feb 13, 2007 7:18 pm
don't swap the radiator, use the tranny cooler section for a power steering cooler. Heat is the major cause of the pumps starting to do the infamous whine that Fords are noted to have.
92 XJ-wifes toy
84_4x4
Posts: 229 Joined: Mon Sep 04, 2006 8:36 pm
Post
by 84_4x4 » Wed Feb 14, 2007 6:04 am
no need to swap radiator anyways can just block off ports and save yourself a lot of time even if you don't wanna cool your power steering fluid
Posts: 743 Joined: Sat Jan 01, 2005 8:10 pm
Post
by ranger5.0 » Fri Feb 16, 2007 8:18 pm
I wouldn't change the radiator just for the fact that auto radiators are a little bigger to help cool the hot oil. extra cooling nevers hurts.
I know I have lost power steering with a welded front on a trail cause of the overheating of the oil.
Good Idea Bob.
