84 Bronco II Hesitation
mwehrle
Post by mwehrle »
I just put a new carb on my 84 BII. It has a flat spot on initial excelleration. It's running very lean. Anyone ever encounter this?
84_4x4
Post by 84_4x4 »
stock style carb or a newer better one
might want to check fuel filter and tps sensor and possible the idle control mixture sylinoid
look down throat of carb and move the throttle do you see a strong spray of fuel
Sounds if though you may have a vacuum leak. Recheck your connections from your install.
mwehrle
Post by mwehrle »
I think it may be a vacuum leak. Although I leaned out the mixture and used propane around all gaskets and hoses with no difference to the idle. I'm going to change the fuel filter and see if that helps.
84_4x4
Post by 84_4x4 »
could have a float stuck in the upward possition try tapping the carb lightly with a hammer and see if it makes a difference also could have a pinched furl line or a fuel pump on the fritz
