exhuast air pump
exhuast air pump
is this a piece of exuipment that is neccesarry for performance or can this be disconnected it has alot of hoses and crap i know one runs to my cat but dont know if they go anywhere else since i am cutting off cat was wondering if this air pump needs to be running to something or if i can just disconect the hose
If your engine is running ok, I wouldn't mess with it. Problem with emissions stuff, you either have to run it all, or none. I've run both ways, and to be honest, I've never noticed a difference. If you decide to remove it all, you should switch to a duraspark ignition and a non-emissions carb.
Do you have smog testing where you live?
To answer your question, yes you can remove it. It's very likely that your intake manifold is completely plugged with carbon, so your EGR probably isn't working right anyway. You can remove the tube that crosses over behind the engine. Cut the ends off, crimp and fold them over to plug the holes on the exhaust manifold.
my engine runs fine and my egr valve doesent mess up unless i really lay into it then go into nuetral is there anything i can do to remove carbon from intake without pulling it or tearing something up
there are no emmisions testing where i live after december 31st so i dont have to worry about that i just dont wanna buy a new cat the only reason im not gonna reinstall
