dead spot
baby bronco
dead spot
i have a 86 bII and its like i ahve a dead spot in my pedal or something....ill be accelerating and itll like stop and sputter and then jsut take off and i dont accel fast or anything what could it be??
OffroadBEAR
baby bronco
OffroadBEAR
baby bronco
tried it all
ive changed it all....o2 sensor,TPS,air filter,fuel filter, spark plugs....i duno what else to try it doesnt have a mass air flow sensor......so i dont know
run codes before you spend any more money...it is free at autozone.
if your going to run codes you can use this sight as well www.fordfuelinjection.com it should help you out.
baby bronco
the codes will tell you what problems your bronco may have... is like a sense nerve in your body it sends a signal to your brain when it senses pain, pleasure, etc... even though your engine check light aint on it may be storing or have codes anyway... there is a way to check codes with out the code checker as well its on the site.
