Is there a clutch adjustment ?
The clutch in my 1985 B2 started slipping yesterday on the way to the local
pull-a-part. The pedal is all the way at the top of its stroke with no free play. Is there an adjustment on these type of clutches ? The manual I
have, mentions nothing about being able to adjust them in any way.
It seems hokey to me.
My sons 1984 B2 clutch has about 3/4 of an inch of free play at the top.
Thanks
Thanks
Thanks Dreded.
The reservoir is full. I will try bleading the system.
If the flywheel is surfaced by .010-.030, it could throw the entire geometry of the clutch release off, am I wrong ?
If the throw out bearing has to reach further to release the pressure plate, the pedal would be higher inside the vehicle. Some type of adjustment sure would have been nice.
If you had air in the system the clutch would not disengage and would not allow you to shift, not slip the clutch. The resurfaced flywheel should not make a difference. The hydraulic slave would take up the slack by using a little more oil. Thus if it was to much travel for the slave it would not totally disengage the clutch, not allowing you to shift.
5.0, That makes sense. I don't beleive there is air in the system.
I am confused about the pedal being tight at the top, no free play.
I think this is slighty disingaging the pressure plate which would make the clutch slip.
When a clutch wears, the pressure plate fingers protrude less which make me think that the pedal should be lower, not higher with a worn out clutch.
Is that correct ?
Thanks
Is that correct ?
Thanks
clutch bleeding
I found out yesterday that my clutch slave is broken (leaking fluid when pedal is depressed) I was wondering if anyone would explain in depth how to bleed the clutch system on the external clutch (84 year). The haynes book i have says you have to buy a prebled system from ford because it cannot be bled in service. I cant believe that it just doesnt make much sense. Thanks
"Dont call him a cowboy until you've seen him ride"
If you have recently changed the clutch, then I appears that something is incorrect in the install. Though I am not sure what it could be unless something was stuck between the slave and the throwout bearing. You are correct though, on the wear theory. It should be getting closer to the floor. My guess would be that they didn't reinstall the shim plate inbetween the engine and trans.
5.0, I am going to look at the clutch a little closer this weekend. It does have the block plate, If that's what you mean by shim plate ? Its the sheet metal cover that is installed between the back of the engine block and the bell housing and usually has the small removable inspection cover at the very bottom.
I have not installed a new clutch.
Do you have a 5.0 in a Ranger ?
It is in progress, I have all the goodies for the install. At least it is sitting on the full size axles now. One project at a time.
The block plate, as you call it, is what I was talkin about.
The shaft from the clutch pedal to the slave, I don't remember if it was adjustable, something to look at before the big clutch job.
I used to spend a lot of time at the dunes in Oregon. I ate shit really bad, in 2001 on a TE610 Husky, basically broke my neck. Things like that tend to slow me down. I still have an old YZ426 and the two Odysseys but have only rode once since last Memorial day.
I'm getting really stinking old,and these Broncos seem more my speed, they are really cheap and I am enjoying the learning curve. I have been devouring every piece of information I can find on them.
