5.0 Install
onewontwo
Re: 5.0 Install
Post by onewontwo »
I'll post one later. In the mean time what should I do about the sensors and harness being all different years?
Re: 5.0 Install
i think i would get them from the same year the computer is.
onewontwo
Re: 5.0 Install
Post by onewontwo »
will sensors from an 88 work in the 86,87 intake? I'd like to go with a mass air set up.
Re: 5.0 Install
i would think the 86/87 intake would work as long as it has the sensor locations in the same spot for the MAF. compare the two intakes
Re: 5.0 Install
well seeing you have the t-bird lower intake
1993-87 302
5.0
4.00
E/T
H.O., Roller Tappets,
Cougar, Thunderbird
196400A 196413AB
block-E7TE-CA/F1SE
crankshaft-2MAE
heads-E7TE-PA
onewontwo
Re: 5.0 Install
Post by onewontwo »
Oh yeah, is the dist. okay to use or not??
Re: 5.0 Install
there should be some casting numbers on it,but if it is orignal for that motor,ya. but i dont know about the MAF conversion
http://fordfuelinjection.com/?p=5
onewontwo
Re: 5.0 Install
Post by onewontwo »
But what ifit was carbed before? Wouldn't it cause problems?
Re: 5.0 Install
well,my friend has a 87 bronco with a 351,and thats carbed. i dont know about the 302
Re: 5.0 Install
onewontwo wrote:But what ifit was carbed before? Wouldn't it cause problems?
shouldnt, ive taken a 88 EFI 302 and carbed it
onewontwo
Re: 5.0 Install
Post by onewontwo »
Ok. I just know on the fordfuelinjection.com site it says to pick one up. Not sure why it would.
Re: 5.0 Install
onewontwo wrote:Ok. I just know on the fordfuelinjection.com site it says to pick one up. Not sure why it would.
pickup what?
onewontwo
Re: 5.0 Install
Post by onewontwo »
Distributer
Re: 5.0 Install
if your doing the MAF swap,get everything
onewontwo
Re: 5.0 Install
Post by onewontwo »
What if I would go speed denisty?
