Spy Photo
will that hold the weight ok? those 36's get heavy.
I am still thinking about where I want to put mine. I thought about in the bed but it might be hard to get it down if I need it. then I thought about putting it on top of the bed but I don't want to kill my rear view, and I think it might be worse if I mounted it in the stock location. are you planning on lowering it a little to give you more view when you look out the rear?
It's should hold up fine. I read about a few spindles breaking, but I think that was more from poor design or abuse.
I plan on mounting the tire high for clearance, although I was considering the possibility of making the height adjustable.
Rockstomper sells a hinge kit
http://www.rockstomper.com/catalog/pieces/hinge.htm
I'm probably going to buy the hinge body here(bottom), and pick up the spindle, bearings and seals myself. This guy also has a nice wheel mounting plate.
http://www.troutindustries.com/
Here's the link to that jeeperman bumper
http://www.jeeperman.com/bumpers/rear/r ... index.html
nice design
. alot of good info here but i just wanted to know what is so bad about the factory swing tire mount ? i know the fibergalss door suck's but a nice ranger tailgate would fix that problem. just wondering becuz im planning on putting a ranger tailgate on just picked one up from Rock's friend. i was gonna use the factory swing tire mount it seem's to hold up well.
