87 B2 MYSTERY PROBLEM! HELP NEEDED
B5150
Re: 87 B2 MYSTERY PROBLEM! HELP NEEDED
Post by B5150 »
i can not get it open ive takin it to my buddies shop on heavy duty vices haha. can i buy a new canister in put the filter in it?
an when i cycle my key i hear my fuel pump an following right after that i hear a air bubble or something odd?
B5150
Post by B5150 »
the sound comes from my tank by the way
the hose fall off the pump in the tank?? take the fuel line off the canister that comes from the tank and turn the key on. gas sholud come out
B5150 wrote:the sound comes from my tank by the way
that could be just the gas from the return line entering the tank
just for shits and giggles, take a small nail/pin and push down on the valve core on the FP presuure port and have some one turn the key on.the gas should just about hit the hood. see if its gas or water
B5150
Post by B5150 »
true it could be the return line. an gas hit my hood jus for sure haha. its not water. i don have my liscsence but i took my truck for small drives evey day its not a sitter. an i just wanted to move it an would just crank its proble somthing so miniscule!
well,you have everything to make it run(cause it runs when ya squirt gas in the TB) but the gas isnt getting through the injectors.hmmmmmmm.
got another computer you can try?
why did ya pull the gas tank out
B5150
Post by B5150 »
i dropped the tank cuz i changed my in tank pump. an my buddie might have a computer i can try actually. how hard is it to get my injectors out? an how can i test there flow?
well???
B5150
Post by B5150 »
its sadly at the shop
:[ i didnt know what else to try. and i guess my buddie didnt end up having a extra computer.
